plug'n'plate or dip
  • plug'n'plate or dip
    1. In refurbishing a silver plate musical instruments like a flute, is the plug and plate finish durable enough for the keys? and would several coatings be needed? or is 'dip' electroplating the recomended way?
    2. If a touchup is done on a worn spot on the main body of the flute, is it recomended to re-buff the area to blend it in?
    Thanks for what you do
    Mike
    "You might be on the right track, but you'll get run over if you just sit there"
    Will Rogers
    Re: Plug n plate kit for bathroom faucets ?
    1. You can control the thickness of the plating equally well with both kits. With dip plating, simply leave the part in the solution longer. With Plug N Plate, simply brush the part more often. The more you brush, the thicker the plate, the more durable it is.
    2. It's likely you'll want to give a quick buff, but not always necessary. In some cases, you might be lucky enough to touch up a part and it blends right in instantly. In that case, why bother buffing?
