For what it's worth, I was a little concerned when I first started plating too. But I've only had one "incident" occur, and it was NOT any fault of the kit or the process- but one word of advice; IF you set up where the heaters are kept near the buckets and all plugged into a shared power strip, ALWAYS check and check again that ALL the heaters are either put in the chemicals OR unplugged BEFORE PLUGGING IN THE POWER. To do otherwise is to smell smoke and then see fire on one or more about 30 seconds after powering up. On the positive side, it appears that none of the chemicals are flammable.
