Can I plate cast iron with copy chrome?
cast iron
The Copy Chrome™ process is ideal for all your small items such as door handles, brackets, hinges, nuts & bolts, stamped steel covers, etc. It can be applied to:- steel, copper, brass, bronze, old nickel plate, and with the aid of Zincate Primer, aluminum.?
That came from caswells website and tat is all I could find so for now the answer is no. I will get a piece of cast iron and try to plate it in my triple chrome system and I can then give you a better answer. If i can get nickle or copper onto it then the answer would be yes.
Ill post back A.S.A.P. on this matter
