What would cause parts plated with COPYCHROME to turn black. I have to keep removing them from my motorcycle for polishing with a cotton wheel every month or so. I have parts that remain inside out of the weather and they don't do it. All parts were 'chromed' for at least one hour at the appropriate current and temperature settings and they came out in excellent condition. I've tried keeping them polished with car wax and recently I coated them with a product called 'Liquid Glass', a clear paint sealer. They still oxidize, is there anything I can do to prevent this? Ken
OXIDATION
I sanded from coarse up to 2000 grit wet/dry paper. Then buffed on 2 wheels to get a chrome-like shine. Then I dipped into SP Degreaser at prescribed temperature for allotted time. (The aluminum parts went into the Zincate solution to preserve the pure clean aluminum finish.) Then directly to the copy chrome bucket for 1 hour at appropriate amperage and temperature. When the parts came out, I buffed them on the wheels again ending with the red rouge for a deep chrome-like brilliant shine. I polished them further with Mothers carnuba wax. They looked great for a while, then the steel and aluminum parts all started to turn black. That is where I am now. Any ideasKen
The copy chrome kit doesn't require a base coat of copper. I followed the procedure of sanding and polishing the pieces to a brilliant shine. Then a dip in SP Degreaser, rinse with distilled water, then into the Zincate solution for the aluminum pieces. Then to the copy chrome bucket for an hour. They all came out great after polishing. It took about a month for the pieces, steel and aluminum, to start turning a dark color. Anything I've kept inside is still fine.
hotshot. I was so perplexed about your situation I called caswell and spoke to customer service, he read your post over the phone and agreed that it was a lack of copper plating that was causing the problem, Have you tried to call them yet? Please keep all us copy chromers posted. Thanks........... John
I find that interesting because the copy chrome kit is designed to work as one step without copper. The instructions state that the first step for aluminum is to imerse it in the zincate solution and go directly to the copy chrome bucket. For steel, all that is needed, according to the instructions, is to polish it, clean it with the SP Degreaser and put it in the copy chrome bucket. If they are saying that I need to copper plate it first, it is contrary to how they are advertising the copy chrome system. I've been intending to call them but I've been distracted with ongoing situations at work. I'll try to contact them on Monday. Be assured, I will post what I find out from them here. Thanks for responding. Ken
Here's a thought.
I know from experience under typical room conditions and over extended periods of time, nickel plating will develop a darkish cast when it oxidizes. This is under room conditions. I also know that nickel electroplate is going to be somewhat porous, so under extreme conditions the substrate oxidation will also show through, whether it is copper or steel. Obviously steel will be worse because it will show through as iron oxide and spread, eventually pushing off the plating from underneath. All this can be accelerated by extreme environmental conditions.
Unfortunately in your application, nickel plating may not be suitable for harsh environmental (heat, moisture, salt, etc) applications. Remember that copy chrome is simply nickel with additional trace elements (eg cobalt) that give it the blue cast of chrome. But it is NOT chrome and does not have the durability of chrome. The reason chrome plating is applied to nickel is to provide the surface durability and protection needed to withstand difficult environmental conditions.
The only thing I can't explain is why waxing doesn't retard the process. That is unusual. I would expect that it should. Are the parts heated to extreme during use (eg engine parts)?
A copper pre-plating will likely slow it down a bit, but it's not clear that it will stop what you are seeing.
Eventually, repeated polishing of the copy chrome will wear through the plating. You might want to consider doing good ol' chrome plating. Personally, I wouldn't set up chrome plating at home, but there are many daring souls out there that do.
There are certain grades and treatments of electroless nickel that claim similar corrosion resistance to chrome. I don't know if Caswell offers these and I don't know if they provide a cobalt tinted formulation either. But there are other forms of chrome (trivalent vs. hexavalent) that are environmentally safer to use.
Kind regards,
Ken
I think you hit the problem right on the head and I think going to a real chrome process is the best thing to do. I'm disappointed though because I was led to believe that this problem wouldn't present itself with the copy chrome kit. I was told that copy chrome was the next best thing to real chrome without all the hassle and the steps required to apply it. I was told also that this process was almost as durable as chrome and that the finish was just a tad bluer than real chrome. At no time was I informed that there was a corrosion problem associated with it. if I was told, I wouldn't have ordered this kit but gotten the triple chrome kit instead. And I was very clear about my intentions to use it on motorcycle parts. Some parts are near the engine like a boot guard on my right floor board to keep my boot off of the hot exhaust pipe. Other parts are a flag bracket attached to the top of the rear fender and a pair of riser/slugs for my handlebars. I used a good quality paste wax on the new parts and that didn't help either. I also applied "Liquid Glass" to them and that failed also. This is a sealer-type product that also protects paint from chipping. Its almost like a tough clear lacquer paint.
One last question, can I apply real chrome over this copy chrome? If so, then I can salvage the parts I've already made and get the chrome finish I was originally looking for. Thanks for your experienced reply. Ken
Ken, Did you ever call tech support @ caswell (Lance) ? And another question I have is, why isnt caswell responding to this post? There has to be a answer for why its so quickly oxidizing and there should also be a way to stop or slow it down. If you have further luck in finding any of these answers please let us know.
Hello,
I would think that you could chrome over copy chrome. I'm not sure you'd be happy with the color, but it should work electrochemically. Given the number of times you've already buffed these parts, I would strongly recommend thoroughly cleaning them to remove every possible trace of coatings, wax, and paint. Then I would repolish and reclean, then heavily replate with the standard nickel formulation which works very well. Don't forget to pickle the parts with the sulfuric acid pickle (I believe Caswell calls it Pickle 3) which is roughly 50/50 battery acid and distilled water--before re-nickel plating. Then do the chrome.
I'm heavily biased against using chrome plating around the house. It is a strong carcinogen and can react with other chemicals to emit poisonous gases. A small amount of chromic acid spilled out can contaminate a neighborhood. I don't feel that way about the flash copper (EPI E-Brite Ultra Cu Alkaline Copper) or the nickel formulation (also an EPI product) as long as waste disposal is dealt with in a healthy way. Personally I have a very small system--1.5 gallons. I would love to build up a bigger system but have great concerns about the environmental and health issues that would pose.
I guess just knowing the nature of untreated nickel, I have only considered the copy chrome for interior automotive parts. So the question of its durability near a hot engine part hasn't ever really come up for me.
Kind regards,
Ken
I must say I don't know. It's tough to tell what is happening to HOTSHOT's parts without seeing it. Best guess is oxidation due to high temperature operation. But could there be hot vapors passing over the parts, leaving deposits? It's just tough to say from here. I DO know that nickel will oxidize black, over time or when exposed to certain acids--even skin oil. But usually the oxidation takes a long time. So, the only guess we have here is that temperature is accelerating the process for him.
A conversation with Mike Caswell is definitely in order.
Kind regards,
Ken
