It's taking me for ever to get bad results
I tried to plate a steel kick stand for my bike and when I was finished I wanted to paint it again>
The steps i took were sand Blasting, alight sanding, soak in #2 pickle, Flash Copper, (everythings good so far) Nickle for 15min this is were the
problem starts, The top and bottom of the piece were very dull and my amps were right. so i buffed and preceded with Acid copper for fill in the blasting pitts 10 to 15 mins a time Acid coppered three times seemed to go on thin for a filler
and wet sanded in between coats with 2000 gr. followed by Nickle again and was very disappointed after the Nickle was applied still pitting and some dark spots Want to throw the piece away Please help
