I just received my chrome plug n plate kit.
I had to use it as soon as I got it...of course. So, i got an old brake dust shield in the garage. I polished a little spot on it with a 320 grit die grinder. Then i cleaned it. Then I wiped it with acetone....wiped it with a dry cloth.
I hooked in the wand, grounded the dust plate. I put a little of the solution in the cap of the bottle. wrapped the wand with some of the provided gauze....dipped it in the solution. I started rubbing the small, prepped spot....slowly at first....and I could hear some fizzing....but saw nothing. I decided to move the wand a little faster and press down...still....nothing. I let it dry...redipped the wand and started again....still....nothing. I decided that maybe if I buffed it, it would make a difference. I got my dremel and some never dull....made it nice and smooth. I polished another small area right next to it with my 320grit die grinder and didnt do anything else to it...I compared the two...they look exactly the same....
Am I doing something wrong?
