My very first part came out far better than expected - uniform coverage, nice bright finish, everything I'd hoped it'd be. Subsequent parts are less so. After about 3 parts, all about 12 sq in, I added another 3 1/2 tsp of brightner per the manual. Altho the next piece was somewhat better, following pieces are not. Is the brightner really consumed that fast?
All parts so far are what I would call exceptionally clean - bead blast, acid washed, detergent washed, SB de-greaser bathed. So I don't think the solution would be considered contanminated. I'm using compressed air run thru a filter into the tank for agitation. Coating still appears to be depositing as expected, just not 'bright'. I can polish them with a little Mother's but then I get a 'polished' finish that looks more like chrome than bright zinc.
Anyone else had similar experience?
FWIW - Two gallon system using supplied power module. Parts are steel with original zinc finish before bead blasting.
