Nickel plating repaired & filled aluminum?
  • Nickel plating repaired & filled aluminum?
    I have an aluminum radiator shell that I would like to nickel plate. It will need to have a couple of areas patched and deep pits and scratches filled first. The process that I have in mind is:
    1 Patch the damaged areas using Techno-Weld.
    2 Use Pit-Stop as a surface filler, like using body putty prior to painting a car body. Sand smooth such that only pits & scratches are filled.
    3 Zincate & anode process nickel plating.
    Will this method work?
    Bill
