The trick is to get Flash Copper on the part first, then it won't matter which finish (electroless or copychrome) you use. Personally I like the results I get with the Electroplated nickel, and the maintenance on the tanks is nearly nothing--unlike electroless.
Please read the extensive posts on plating pot metal. You're in for a real ride.
Kind regards,
Ken
plating pot metal
