I have just started plating as a hobby and I have ran into my first snag. While plating aluminium with electroless krome, bubbles appear to be underneath the plating. I degreased the aluminium with acetone then zincated it first. What am I doing wrong
problems with bubbles
Re: problems with bubbles
This problem is addressed in the manual and can be solved by aerating the part with larger bubbles from an airstone during plating.
Please use our technical support section at http://www.caswellplating.com/support.htm to post further technical support related issues. This forum is not set up to handle requests properly and in a timely fashion.--
