Hi,New to the site. I have previous plating and sandblasting experience. I have a X-mas tree ornament that I would like to silver plate. Will clean to base metal. I need info for a small copper flashing tank. Ornament is 1/32" thick,3" dia. Steel base metal. Once flashed and buffed I will purchase the brush silver plating kit. Then I would like to, set up a small silver plating tank to make the item thicker. I also have electronic experience so no problem with a power supply for the plating process. Any help appreciated,Thanks,Fred
