Newbie with prior plating experience. Question: After de-greasing,pickling,copper flash plating is acetone a suitable cleaner before silver plating? Does it leave a residue? Yhanks,Fred
Acetone
I'm not inclined to encourage anyone to use volatile solvents for cleaning anything these days. Acetone is very effective at dissolving a range of greases and waxes, but not all. Will it leave a residue? Absolutely, unless you keep the solvent clean, and/or use multiple rinses. I'd advise using a strong water based detergent in conjunction with an ultrasonic cleaner. But NEVER use a solvent in an ultrasonic, especially one with a heater.
Ken
Acetone
Originally posted by dadkar2I'm not inclined to encourage anyone to use volatile solvents for cleaning anything these days. Acetone is very effective at dissolving a range of greases and waxes, but not all. Will it leave a residue? Absolutely, unless you keep the solvent clean, and/or use multiple rinses. I'd advise using a strong water based detergent in conjunction with an ultrasonic cleaner. But NEVER use a solvent in an ultrasonic, especially one with a heater.
Ken"Viva Zapata"
