Hello, yes I am a newbie. I have purchased the triple chrome kit and I am trying my best to understand everything before I start my first piece. I will try to short and hope not to get too long here.
I have completed setting up my table and tanks. I have read the manual and watched the tape atleast 5 times each. I have spent no less than 10 hours reading in the forum. I want to make sure that I control the hazards and protect the enviroment the best I can. I hope that someone responds to my questions as with my last post no one ever replied. I ended up just deleting it.
1. I noticed, in the training tape, that each time a part gets rinsed that it is done over the tank it just came out of using a spray bottle. I understand how this keeps the residue with the original solution and keeps it from getting contaminted.
Does the part ever dipped in a distilled water tank?
2. If so, how do you top off the plating tanks using the distilled water used for rinsing when residue from each solution ends up in the rinse water? Contamination appears to be very important and I do not see how to keep this from happening without seperate washing tanks for each solution.
I have many more questions but answers to these would help alot for now.
Thanks
Jeff
need1moretool
Thanks
Jeff
need1moretool
