Copy Chrome Kit
This topic is closed.
    Re: Copy Chrome Kit
    Please go to http://www.caswellplating.com/support.htm and use the procedures there to get a password, or send me an e-mail with your invoice number and I will send login info.
  • mr.wagon
    Re: Re: Copy Chrome Kit
    caswell wrote:
    Hello:
    We really need more information from you in order to help solve a problem. We\'ve set up a special support area for these sort of questions. It\'s at http://www.caswellplating.com/support.htm
    Use the login name and password found on your invoice to gain access. Then go to our Problem Resolution System (PRS) and create an account for yourself. Once there, create a problem report and fill in all the fields such as temperature of bath, current used, duration etc. Then we can help you properly.
    Thank You.
    I dun find any password and Login ID in my invoice...
    Re: Copy Chrome Kit
    Hello:
    Thank You.
  • mr.wagon
    Re: Copy Chrome Kit
    I have tried to plate the copper and copy chrome, but I find that the plating process is very slow, why?
    Re: Copy Chrome Kit
    Please read the manual. This is clearly explained in the Copper and Copy Chrome sections. Thanks
  • mr.wagon
    Re: Copy Chrome Kit
    Can I plate without operating the heater?
    If no, what temp. should I maintain the Copper Plating kit and Copy Chrome Kit?
    Re: Copy Chrome Kit
    Just scrape or soak the sticker off.
  • mr.wagon
    Re: Copy Chrome Kit
    Thank you, and the anodes have sticked with stickers, can I immerse them into the solution without removing it? If not, how can I do?
    Re: Copy Chrome Kit
    This is all explained in the manual. Have you given it a good read yet? All of these questions you have asked can be answered from reading the manual.
    You place the heater so the glass part is immersed, but the plastic part is not.
    Yes, battery acid is the stuff that goes in car batteries.
    SP Degreaser is used for degreasing, surprisingly enough. You heat it up and immerse parts in it.
    If you have other product support related questions, please post them to our technical support area (PRS) at http://www.caswellplating.com/support.htm
  • mr.wagon
    Re: Copy Chrome Kit
    I have got your Copy Chorme Kit and Copper Plating Kit, but there are some problems.
    1. Is the heater completely immerse in to the solution? Or just immerse the glass tube into the solution?
    2.Battery acid is the liquid then fill the car battery?
    3. How the SP Degreaser work? And what does it for?
    Re: Copy Chrome Kit
    Sure, you can use anything, including a car battery or battery charger.
    However, you do need a way to control the power. You can just hook up a car battery to the plating tank, as it is usually too much power to plate small items.
    There\'s a technique in our manual using lightbulbs that most people find easy to do.
  • mr.wagon
    Re: Copy Chrome Kit
    Can I use a Power Supply to provide electricity, not use your rectifiers?
    Re: Copy Chrome Kit
    Sorry, I don\'t understand your question.
  • mr.wagon
    Re: Copy Chrome Kit
    Is Power Supply can be the power source in the plating process?
    Re: Copy Chrome Kit
    A plated finish will last indefinitely, assuming it\'s in a no-wear environment and is taken care of.
    You\'ll likely need to give it a light buff after plating to bring out the shine.
