Electroless nickel and \"regular\" nickel other than method of how the plating is applied?
what is the difference between .....
Re: what is the difference between .....
The method of application is the only difference.--
There are a couple differences along with how its applied.
Electroless is usually thinner plating then the electrolytic type.
Also instead of anodes to give up metal for plating the metal comes out of the solution and onto the part.
Eventually the solution will have to be replentished.
48 Buick
