1. I assume you can heat and cool down the solution as needed or once you mix and heat do you have to use it all up?
2. With evaporation I am guessing just the water evaporates not the chemicals. So for example if I plate 30 sq. inches in one sitting and come back a few days later obviously my chemicals are still ok but my fluid level may be down because of evaporation so I owuld just need to add distilled water becasuethe chemical do not evaporate is this correct?
