plug + plate
  • plug + plate
    I have a set of golf irons that are chrome plated and show considerable wear. Will the plug +plate system do the job on this?
    I'm not convinced plug n plate is for large parts. I use it extensively for small parts; eg, screws, small finials, finishing nails, etc--especially with gold. I much prefer immersion plating. Gold is tough to do as an immersion plating process due to the cost and shelf life issues. So I always plug n plate with gold.
    Also, the nickel levelers and brighteners don't really have a chance to do their job with the plug n plate method.
    Ken
      Oh, one more thing. For touch up repair, plug n plate is great too.
      Ken
        Shelf life of gold?
        Ken, how long is the shelf life of the gold solution for tank plating?
        I just ordered/recieved a quart (2) weeks ago along with a 24ct. gold anode.
        I have read some posts about the gold settling out of the solution (after some period of time) and then it is shot.
        Just wondering.
        BTW: The gold plating I am doing is coming out fantastic.
        I saved the company over $800.00 during the first 2 minutes of gold plating thanks to Caswell's supplies.
        Side question:
        Could I use a 14ct anode (verses the 24ct anode)?
        Reason: To have a more durable (harder) gold surface for electrical contacts (I have a few old 14ct rings I could melt down to make anodes).
        Will any adverse effects (such as screwing up the solution) crop up?
        Thanks!
        George W.
        Orlando, FL
          George,
          I really can't give you an infornmed answer on either question. These are best left to Caswell's support. I understand some had a concern about the shelf life and Caswell were investigating it with the supplier, but I never heard the resolution of that. It has been a few weeks.
          As far as the anode, I don't believe the gold solution dissolves the anode in any case, so the gold will come out of the solution--not out of the anode material. In this case, Caswell's stainless steel anode is all you need. You might check with him and then update us in this posting.
          Ken
            Oh, one more thing. I have had my latest batch of FastGold for over 2 years and it is still in solution, just fine.
