I want to plate an aluminum sheet 11\" x 21\". [the sheet has been folded to form the top and sides of a box]
this is 1.6 sq ft/side. 3.2 sq ft total surface.
\" A 12 to 15 volt DC power supply capable of 15 amps per sq. foot of workpiece surface area.\"
http://asuwlink.uwyo.edu/~metal/anodizing2.html
does this mean that I will need a 30 amp rectifier for this project? Is it possible to use a lower amp power supply, and let it work longer?
thanks for any advice.
