I have some through holes on a circuit board and I was wanting to plate them.
The basics are that if I can plate the hole that is punched through teh cicuit board, I can run current from one side of the board to the other (let's say I have a double sided circuit board).
I'm a little lost as to how to approach this project. I am even wondering if plating is really a viable option.
Can someone anticipate any problems I might have.
After reading the forum topics it appears that If I use silver paint as a primer, then I woudl have to nickel coat before the application of copper because the pH of the solution in copper plating will degrade the primer.
any suggestiosn woudl be appreciated.
dave
dave
