Mixing the pickle Baths
  • Mixing the pickle Baths
    When mixing a acid bath. Is the amount of acid used measured by weight or fluid oz.?
    Thanks Tim
    ACID IN COPPER PLATING BATH
    Hi Tim...
    For optimim results...Sulphuric Acid is used as follows...Per Gallon of Acid Copper Plating Bath Solution...
    7.5 Ounces by WEIGHT...or...
    4.1 ounces FLUID.
    - etcc
    "1,200 Year Old Highlander Immortal"
      Thanks for your help. I had forgot about this post.
      Tim
        Hmmm
        You're welcome Tim...it's IMPORTANT to know that difference.
        Also...be sure to add the Acid to the water...NEVER water to acid...and stir well while slowly pouring it in...avoid splashes.
        Which part of Ohio are you from?
        I wish you great success in your plating and all you do.
        - etcc
          I'm from North Canton. I started using Caswell's Copy Chrome kit first and then I moved on to Acid Copper. Right now I'm having great results so I don't plan on moving on to Triple Chroming anytime soon. Thanks again for your help.
          Tim
