Hi,
The first few parts I plated came out good. Then I tried to plat a part that I think had zinc on it. Now everthing is part shiney and part dull. I read about "plating out" the zinc, and tried for hours, but it is still the same. I checked the ph and it is a bit high (around 5-6). The manual says to adjust it. So, my questions are:
1. If I can't plate out the zinc, maybe it is some other problem. Any thoughts?
2. Is it ok to use pool chemicals to raise/lower the ph?? I couldn't find anything in the manual about what to use.
Thanks for your help!!
M
M
