How to Copy Cad
  • How to Copy Cad
    I have the copy cad kit and want to mainly do nuts and bolts. Is there a simply \"How To\" for this. I hate manuals and found conflicting directions in it. Do I need to hang every nut and bolt from the the tank bar using copper wire? How do I tell which is the positive wire on the charger?
    Do I need to cut the anoide in half or is one lead (-) go to the bar and the other (+) go to the aniode?
    As you can tell by the questions this is my first time.
    THANKS to all in advance.
    Re: How to Copy Cad
    Yes
    It should be marked?? It\'s usually the red terminal with the + sign on it.
    The positive lead is connected to the anode. The negative lead to the tank bar.
    Try to forge through the manual. It has a LOT of valuable information.
    Also e-mail us where you think you found conflicting information please. We\'d like to correct any errors that may appear in the book.
