Someone had a similar problem like mine, but just to let you know that I am going from cyaniade to flash from caswell. My problem is the alum. I am getting very small blisters and just a few and they might take a few days to even show up but I get nervous every time I do alum. I have tried a lot of different methods and found that my temp. and amps or very important but is my acid copper the same. I have to go lower than I think on the amps just to make sure it doesn't blister but is it a easier way like you said, go 50% more on amps for 30 seconds and then drop down on amps. It does good on pot metal and steel.
My plating shop is doing good unless I get a lot of alum. then I start making mistakes and get behind on jobs, I guess I am not comfortable with the flash yet and have to get all the kinks out.
