newbee plating question
  • newbee plating question
    I am interrested in plating AL. and steel wheels. approximately 15-20 in. I want to keep my setup fairly simple. what is the minimum chemical and tank requirements for using the tripple chrome kit and the copy chrome kit. Any advise is welcome.
    You'd better have a SERIOUS power supply.
      Start by looking at Caswell's wheel plating kit, and then add about another $5000 for other materials that you will need. Chrome takes 1amp per square inch of surface area.
