I need to get setup to hard chrome small engine crankshaft rod throws.I will need to make some sort of sealed mold so as not to get any chrome onto the crankshaft counterweights. the throws that I will be hard chroming are "1.00 diameter and .94 wide. what actually is hard chroming? what chrome depths are attainable? does this sound feasable with a setup from caswell? btw the hard chrome will be ground on a crankshaft grinder after plating.
Thanks
Thanks
