Copy Cad - PH falls too low - 4.4
  • Copy Cad - PH falls too low - 4.4
    I am wondering why the pH of my Copy Cad solution fell so low ? Is this an isolated, one time occurance or does the solution "TEND" to fall as you electroplate more items in it?
    Also, I have found it difficult to locate Ammonium Hydroxide locally so will be ordering a pint from Daigger.com.
    Are there any side effects or consequences to the plating process or quality after raising the solution's pH with Ammonium Hydroxide?
    Thanks
    0
    Yes, it stays constant and does not fall
    0%
    0
    No, it tends to fall as I plate more objects
    0%
    0
    Charlton:
    My zinc solution is sitting right at 6 Ph, and I've been using it for over a year. I estimate I've done 1000 sq-in (+/-) in that time.
    Are you using an acid pickle pre-plate? Perhaps you're getting acid drag-in.
    OTOH, I have NO information about what the Ph is supposed to be to begin with, and I never measured it until long after I had been using the electrolyte.
    My Plating manual list the pH as "NE" = "not established"
    Where are you getting the info to use ammonium hydroxide to adjust it?
    Sean
    Seans Zinc Plating page
      Hi sean,
      No, no acid - pickle. The parts are thoroughly cleaned, rinsed in plain water and dried before electroplating.
      I have version 8 of their plating manual and it calls for 5.5 - 6 for the pH allthough it does say that lower pH's are ok...down to 4.6. Below that no good. I'm at 4.4 - 4.3
      I'm thinking my solution "MAY" have been damaged by a malfunctioning thermostat. I just used my set up for the first time yester day and set the thermostat to it's lowest setting then insured that I had it plugged in so that the heating element was connected to the thermostat.
      Anyway, it seemed that it was taking too long to shut off the heater so I measured the temp of the solution with a laser thermometer and sure enough it was a sizzling 165 F ! So that may be the reason for the low pH but I'm not sure.
      After tapping the temperature sensor a few good times, it now seems to be working.
      The manual also says ammonium hydroxide is used to raise the pH. But it costs a whopping $50 after Haz Mat fees and $13.00 shipping. (Seems like excessive shipping for a 1 pint container since they're already charging an additional $20 for haz mat)
      I wish I knew of a local source. I'm dead in the water until I can raise the pH and that REALLY blows. I'm having trouble getting the plating to start now and I think this is what the manual says will happen with an excessively low pH.
      Until this, GREAT results on my first 7 pieces. They look Chrome
      I wonder if Zinc Brightener lowers pH ?
        Charleton:
        So they've added that info since my manual, nice to know.
        Since I'm still at the "ideal" 6 pH, and yours is too low, that's a good possibility. I'm no chemist, so I don't know what effect the 165º would have. Have you asked Caswell directly through their tech support?
        The highest temperature I ever got to was 110º, for a one-time test (which didn't work), and it doesn't seem to have affected my pH.
        I don't know. It DOES affect electrolyte conductivity though, which is why I'm convinced that you need a CC power supply to get good consistent results.
        Sean
          What do you mean by that?
            No, not yet...maybe I should?
              Charlton:
              Early on, I had difficulties getting good plating, and was told to run the electrolyte at 110º. Although I had my doubts, I tried it at 110, and the results were worse. I've since found that 65-70º works best.
              Sean
                Wow...that seems too cold. Do you get good adhesion ?
                  Charlton:
                  Yes, good adhesion, smooth & consistent plating. The temperature range is given as 60-90º, so that's well within parameters.
                  Sean
