I read that you should NOT use brightner if you're going to use a Chromate
Blackener photos
If I can't use Zinc brightner with chromates, will the chromate "brighten" the part?
Caswells yellow chromate does brighten to it's own degree. Here's a sample piece done w/out brightener:
A larger image here.
The final "brightness" of the part also depends on the pre-plate mechanical finish. A polished part will come out quite a bit brighter than a bead blasted part.
And finally, and acid bright dip makes a difference. And here, 1% nitric acid is the cats meow.
Initially I had been using muriatic, then sulphuric acid bright dips, but noted that most commercial operations used nitric. Nitric acid is very difficult to come by, but I finally got some, after 6+ months of trying.
The difference between nitric and other acid bright dips is like night and day!
Sean
