Ok here goes my first question, I have the 3.5 gal triple plate chrome kit. I plated yesterday for my first time!
I was able to plate a very good nickel plate onto 1/2 copper tubes, actually this went pretty easy for me so I moved to copper, which was actully prettty good, i got the pink salmon color. At that time I tried a plain copper tube into the chrome, results were fine for not having any nickel on the tube. the chrome plating was reflective but not as shiney as it could be with the nickel underneath. He is where the question comes, I started the triple plate process on my first copper tube for my first complete process. With saying that, the copper and nickel came out just as decribsed above. The problem was when i tried to plate the chrome. I had correct amp 21 sq inches = 21 amps ( I had 21.3 amps) temperature was 113 respectfully, the tube stayed in the bath for 3 mins, when I removed the tube it was a milky grey color, I was just wondering what I did wrong? Should Chrome plating come out shiney? I did rinse, polish ,degrease, and water break after each stage. It just sucks to have a beatiful nickel shiney plate an ruin it...
any help would be appericated!
