Is it necessary to dechrome chromed parts before silvering them? What is the best voltage and temperature for silver? Thanks alot, Gus
silver plating
Slver Plating
I have one also: I purchased a Copy Chrome PlugNplate Kit and a bottle of Silver Solution. May I use the wand from the Chrome kit for silver plating or do I need a silver anode? What is the wand made of?I Rework Sax Mouthpieces. Some photos at www.mojomouthpiecework.com
Silver Plating
Yes you need to de-chrome the silver first.
Are you talking brush plating or tank plating? Tank plating requires 1.5-3 volts and 0.007 to 0.003 amps per square inch. 75 degress F works best.--
Silver Wand
You can use the Copy Chrome Plug N Plate Wand to plate your silver. The wand is stainless steel.--
