I want to plate some putter heads with a black shiny finish (black nickel?) I am also a COMPLETE novice to plating, so forgive my newbie questions.
From what I be able to research on the Web, plating nickel to die case zinc is a pain compared to plating to brass or steel. True? I would like to use the simplest electroless process if possible.
Next question: If I hand-stamp a piece, should I do it before plating or after?
Also a quick question about paint. If a piece is nickel plated, can parts of the piece be painted. I'm speaking about the sight dots and lines on a putter.
Thanks,
Brad
Thanks,
Brad
