Plating putter heads
    We don't sell/know about black nickel, but we can advice for regular nickel. The process is likely similar.
    You'll want to strike the die-cast first with either Flash Copper http://www.caswellplating.com/flashcopper.html or Pot Metal Primer (Electroless) http://www.caswellplating.com/alzinc.htm
    After priming, plate with the regular electroless nickel kit http://www.caswellplating.com/electroless.htm
    Hand stamp before plating to avoid fracturing the plate.
    Sure - you can paint over it.
  • bemclaughlin
    started a topic Plating putter heads
    I want to plate some putter heads with a black shiny finish (black nickel?) I am also a COMPLETE novice to plating, so forgive my newbie questions.
    From what I be able to research on the Web, plating nickel to die case zinc is a pain compared to plating to brass or steel. True? I would like to use the simplest electroless process if possible.
    Next question: If I hand-stamp a piece, should I do it before plating or after?
    Also a quick question about paint. If a piece is nickel plated, can parts of the piece be painted. I'm speaking about the sight dots and lines on a putter.
    Brad
