I'm getting some areas of black streaks. Some areas I don't think are getting any zinc at all (when I try to do the Yellow chromate it is very patchy).
I've been using Aluminum oxide to blast with, I don't have beads. The surfaces are pitted a little, but I'm not really worried about the appearance so much as rust protection.
Is it the aluminum oxide blasting that is causing the problem?
I'm also having a tought time estimating square inches, but I'm trying to get close to the 1 amp/40 sq. inches the manual recommends.
Do I need to re-do a dummy?
