Hi Caswell, I am having success silver plating harmonicas! A few questions: What is the percipitant forming on the bottom of the solution? Is it best to leave it be or stir it up. Should the solution ever be filtered? What is the chemical composition of the solution? Is it dangerous to get a little on you fingers? Is sterling silver ok as an anode or is pure silver best? I seem to have best results plating in stages, polishing a little between dunks. Is this typical? Thanks again. Gus
silver plating
I seem to have best results plating in stages, polishing a little between dunks. Is this typical?--
