Excuse my near total ignorance of electroplating... I have a home project and I'm considering going the diy route for copper plating, but I figure it's probably best to get some perspective first from those who have done this sort of thing before...
My house has a ridge/soffit vent system in the roof. I started painting some of the ventilated soffit panels before I realized they were part of vent system. Now it's a mess. Paint needs to come off, and nothing matches.
I would like to copper plate all of them... all around the house. It's a 2k square foot house, so it's a good amount of plating. I'm guessing, but I'd say each panel is made of some sort of coated metal, and has a largest dimension of a bit under 2 feet. If it's possible to copper plate them, then they'd match mailbox, doorbell, etc... unlike painting them, plating should still allow air to flow through... a few microns here and there won't make a difference in their vents, but the paint is plugging them.
I would also, it the above works, like to copper plate maybe the switchplates, etc around the house.
I have taken a brief look at some of the kits available, but can someone give me a rough idea what I'm looking at here? Can the soffit panels even be plated? Do I need to find out more about their composition first? What about the ones with paint on them? Just strip them and go? Something else?
The finish doesn't need to be perfect here... no one ever sees them up close.
If it's doable, what's the cheapest way to do it? Should I provide the container myself, and buy the chemicals... can I get the battery part locally? I realize at the least I will need specialized chemicals to get the copper, but what about the other bits? Pieces are rather large that I'm plating.
Any help greatly appreciated.
