Is it a good idea, or just an outright bad idea to plate a threaded rod that will have a tight fitting nut drive nut used on a semi daily bases?
Plating Acme threaded rod
Re: Plating Acme threaded rod
Its ok just dont plate very long in each bath.
Steal with a brass nut - very well worn with about 0.005" of backlash where it should have less than 0.001". Given rebuidling the screw would cost around $750, building a screw would cost anywhere from $300-1,000, so I want to plate this screw to tighten it up enough to use.
I don't think this will be a permenent fix, so I'm just trying to get a feel for what kind of like I can expect out of this screw if I plate it.
The screw is about 7/8"x10 pitch and I thought it was the nut - till I noticed there were portions of the screw that were tight but most of it was not. So that's why I want to plate the screw to make it tighter over more of the travel.
