Calculating surface area
  • Calculating surface area
    When calculating surface area do i need to double it for front and back of item.
    eg: one side of the brass sheet is 10" x 10" = 100sq"
    thats for one side so if i am using a tank should i be calculating my amp power at 200sq"
    thanks
    Re: Calculating surface area
    Yes you should, unless you mask one side off so that it doesn't conduct electricity...
      Thanks
      and what would be the best thing to mask it off with?
      regards
        If the piece is not big I would use electric tape or if its big then paint it with a cheap paint....
