Power - what are options?
  • Power - what are options?
    I am in the "considering it" stage of possibly buying a Copy Cad system. Probably the largest part I would be plating is my brake booster servo, which is a round steel assembly that comes in two halves. I calculate the surface area of the larger piece to be around 225 Sq Inches. (its round, 7.5 in diameter and about 3 inches deep). So, I figure I will need the 3 Gal kit, does this sound about right? But for power, I estimate I would need 5-6 Amps, which would mean needing the larger 10-amp powersupply they sell here. With the cost of the kit, this would put the investment at over $500, which is difficult (for me, given the amount of use it would get) to justify. So, the question is, what are my options on power. Could I use a car battery for example? I would rather have something that has more control, but the more affordable 3-amp supply would not be big enough (at least not for the brake servo). Any thoughts on alternative power sources?
    Thanks,
    Basil
    Re: Power - what are options?
    A suggestion for you. I send the bigger items out to professional shop to be plated. The cost is way cheaper. I do the smaller items that are a nuisance to the professional shop and I don't have to worry about them losing the small items. You'll have a very hard time cost justifing the power source, chemical, equipment and time. I have the 3 amp source and if I have anything to do that's more than it can handle I clean it up and send it out.
      Probably not a bad suggestion, but as I have three cars I'm restoring (eventually), I'd like to get something that will do most of what I need without the need to send out (very large items like bumpers excepted of course). Anyway, I may check my local surplus store for something that will suffice (and would be cheap like me).
      Basil
        If you look hard enough you'll be able to find something cheap on ebay. There are tons of supplies for sale at any given time. I've bought a few, most recently an 8V / 50A supply for $45.
          If you want to be more adventurous, you can build a lamp controller for pretty cheap. I built a small one out of car lamps supplied by a 6 volt battery for about 30 dollars canadian. It can produce about 20 amps which is good enough for copper and nickel. For chrome I built two larger ones (30 car halogen lamps each) supplied by a 12 volt marine batteries. Together they produce 400 Amps. Construction cost about 400 dollars.
