I have been plating steel with bright nickel and getting outstanding results. I recently expanded this process to plating some items I made from 6061 aluminum.
Dipping in the zincate as per instructions gives a "charcoal grey" coating to the aluminum. When I move to prepare the part for nickel plating, the SP degreaser results in a reaction with a moderate amount of small bubbles liberated from the part. Subsequent bright nickel plating results in a plate which peels right off. This result is indicative of inadequate cleaning, but I cannot find the problem since the zincated part's preparation is the same that I use for steel preparation which works fine.
I suspect the problem lies in the prep. of the part prior to zincating or perhaps the zincated part requires some prep. prior to nickel plating that I am not aware of. Any help will be greatly appreciated. Thx. J Gray
