Yes, to water.
You use 1oz of sealant per gallon of water, so 1 lb make 16 gals.
Nickel Acetate?
Ok, I take it this is an additive to the water?
How much sealant does 1Lb ALSE22 make?
It's a proprietary formula made by a MAJOR Anodizing supplier. Yes, it has everything needed to do a professional job.
Is your Anodizing Sealant ALSE22 pure nickel acetate, or does it also contain special complexing agents and surfactants and dispersants?
[/quote]
Yes. It's the anodize sealant product. See http://www.caswellplating.com/aluminum.htm
Nickel Acetate?
I saw on another post where Nickel Acetate can be used for sealing anodise (don't remember seeing in the manual, must've missed it). Where do I get it? Do you sell it?
Thanks!Tags: None
