Hi all...It's my first time here. Be patient, I'm destined to screw up somehow...lol
Anyway, I've been doing some type II aluminum anodizing for quite some time now with terrific results. I started with small and slowly moved my way up to a larger scale setup (40 gal tanks). I do a fair number of paintball markers and have not yet come across a hitch - until today. I've done oodles of markers and when it came to do my own, I hit a stump! To present, I have always stripped the original anodic layer off with Caswell's anodizing & chrome stripper. Thus far this has been fruitfull but today when I when to strip what I believe to be chrome of my trigger (aluminum base metal), I couldn't get it to work (I've never tried stripping chrome before).
I should also mention that this chrome has a tinge of brownish to it and fingerprints are often left in a sort of bluish hue. What I think is chrome may be something else but I really believe it is chrome (perhaps nickle) plated.
What I did is as follows :
Using the Caswell anodizing & chrome stripper at room temperature (71F), I connected the negative lead of my 12 battery charger to a steel cathode and the positive lead to the chrome plated trigger. I submerged the cathode and the trigger into the solution and let sit for what seemed like forever. Running the battery charger at 12v and 2 amps the cathode and trigger both bubbled immesley, however, the chrome did not appear to come off the trigger. I should note that the steel cathode did turn black.
My questions to you are :
1. Doesn't chrome have nickle underneath?
2. Is it possible that the chrome has been stripped and I am left with the nickle at this point?
3. Once the chrome is gone, how do you remove the nickle? I need to strip this baby down right to the bare aluminum.
Thanks for any help you can send my way...I'm really stuck on this one!
