Best Way To Prep & Plate Nuts & Bolts
This is a sticky topic.
  • trifivepreserver
    Seanc, I don't know if this will see this but a question on the dangler. Can a section of copper tubing be substituted with a connecting solid core wire be used instead of the stainless dangler and braided wire? It is not clear to me why the piece of stainless and braided wire is used. The braided shield used on TV cables isn't available that I know of. Thanks
  • dzertracer
    Re: Best Way To Prep & Plate Nuts & Bolts
    I've done a lot of old motorcycles using copy cad system. One of the best ways I've found to strip and clean nuts and bolts using a glass bead blaster is to get a plastic bottle like a vitamin bottle 2 to 3" diameter. drill a hole in the lid to make a tight fit for your nozzle. Drill a whole bunch of 1/8 holes in the bottom of the bottle, the more the better. Put about 10 nuts, washers and or bolts in the bottle and put on lid. Put nozzle in lid and start spraying. While you are spraying you must shake the bottle to keep the parts moving around inside. It will clean a bunch of parts quickly. Glass finish will give you that vintage plated look. By wire wheeling or polishing the metal, the brighter the finish will be. Make sure you have already removed ALL grease and oil from parts before blasting. I've seen so many people restore motorcycles and paint the fasteners silver which looks cheap. These systems make you proud of what you have built and much more professional.
  • goldrapt
    sorry for the bump but this was a good read.
  • UncleFestes
    Had to Edit this post due to Brain Freeze
    Last edited by UncleFestes; 03-02-2009, 01:20 AM. Reason: Extremely Dumb Question. I need to read a little.
  • NOL4154
    Depends your volume:
    Using wire for plating can be a disadvantage because plating thickness will vary. It may look like its plated but could have a flash.
    Look up "barrel plating"
    Nol4154
    What is the best(fastest with good results) way to prep a lot(50+) of nuts and bolts for plating?
    Also, what is the best way to plate them?
    This is for CopyCad.
  • roguedog
    Wow! Very ingenuis. Thanks for the posts and links.
  • seanc
    My plating pages have moved, but can't edit my previous post. New location:
    Plating Barrel
  • seanc
    It's been a long road, but I finally have a functional motorized barrel plating setup:
    It's not perfect, and I continue to investigate improvements, but if you can adapt the design to your own needs, go for it & post the results!
    Sean
  • seanc
    Re: Best way to prep & plate nuts&bolts
    Greg:
    You might try the motors they use for making fishing rods.
    I'm not familiar with making fishing rods. Sounds interesting.
    However, I have the ideal motor now: barbeque rotisserie motor. They turn at just the right speed, 4 RPM, have gobs of torque, and are designed for continuous use.
    I have it set up for motorized use now, but still haven't quite got a fool-proof electrical connection to the parts, so haven't posted an update. When I figure that out, I'll be posting a full update.
    Thanks for the tip though!
    Sean
  • overcashier
    You might try the motors they use for making fishing rods. I built a rod making set up and the little motor seems as though it would have enough torque and turns pretty slow. I think it would turn your plastic basket.
    Greg
  • seanc
    Woody:
    This may sound dumb, but how do you ensure that the SS rod or butter knife is in contact with all the parts all the time?
    Well, those are the "kinks" I haven't worked out entirely. Particularly a mounting which would hold the rod in just the right position all the time. It really needs to be spring loaded so it can shift position with the parts as they tumble.
    Some large commercial plating barrels use this method. They call it a "dangler". Some danglers are large balls which simply ride on top of the parts pile. Others are thin rods which get surrounded by the parts. Of course, they are complicated devices using slip rings for electrical contact, while I'm trying to keep it simple. The tradeoffs aren't as easy to overcome as I figured.
    Does it just touch one, and they then touch each other?
    Exactly.
    Don't know how well this would work for nickle or copper. The current in zinc is fairly low, so it passes through the parts easily.
    Sean
  • dwoodruff
    This may sound dumb, but how do you ensure that the SS rod or butter knife is in contact with all the parts all the time? Does it just touch one, and they then touch each other? i am using the copper, and nickel kits, so i'm assuming, i'd do the same thing with the copper wire, or a copper pipe?
    Thanks again.
    Woody
  • seanc
    Woody:
    how do you wire it up for the power? and how often do you rotate it? i have the round buckets, so i guess i'll have to modify it a bit.
    I use a stainless steel rod and dangle it in the basket on top of the parts. I've also used an old SS butter knife. Still need to figure out how to mount the electrical connection permanently though.
    I figure anything around 3-6 RPM works. Haven't yet found a strong motor that slow, so I'm still turning it manually. Every 15-30 seconds I'll turn it over.
    I still haven't worked out all the kinks though. Just haven't had the time since last fall.
    Sean
  • dwoodruff
    i love your barrell design, i've been looking for something similar... i have one question, though... how do you wire it up for the power? and how often do you rotate it? i have the round buckets, so i guess i'll have to modify it a bit.
    Woody
  • seanc
    They all plate just fine:
    But it's just too time consuming to do a high parts count this way. For anything more than a small handful, a barrel is the best solution.
    Sean
