Container to use as anodizing tanks?
  • 48Buick
    Plating tanks
    Tim:
    You can use the storage type containers but make sure on the bottom of the container it has a recycle triangle that has the initials PP in the center of it. The HDPE and LDPE containers are kind of flimsy for plating and anodizing. You might also think about using two of them stacked for more strength.
    48 Buick
  • Tim Wiltse
    started a topic Container to use as anodizing tanks?
    I'm looking into getting some different "tanks" to handle different size parts to anodize. I'm using the 3 gallon from Caswell right now. Would waste baskets made by Rubbermade work?
    Thanks alot,
    Tim
