Ok I have a Magnum research desert eagle, which I want to do some custom work on, but the problem i have is the bore and the chamber, How would you keep the plating from well plating the inside?
I read the masking areas post. and don think it's apporiate, but ??
Ok and the next question Electro or Non-Electro, whats the difference.
Thank You,
Paul
Thank You,
Paul
