If I dye an aluminum object, and it isn't right do I have to put it back through the anodizing process (acid/battery charger process), or can I just strip, clean and dye?
Also what if anything will happen if I mix one container of dye w/ 1 gallon of water instead of 2?
What exactly does the desmut process do? I don't quite understand that. Will it remove fingerprint greese?
Thanks
Thanks
