i was wandering what kind of metal prep is needed for a old nickel plated pistol all the nickel was sanded but i dont know if all needs to be removed or can i just start plating it when my kit comes in and what can i use to clean it prior to plating it so there are no oils or fingerprints on it and what do i do to keep the cylinder and barrel bore inside from being plated
