I was planning to buy a Plug and Plate kit to plate several bolts on my motorcycle. Then I read somewhere that zinc bolts need to be stripped with acid before plating. Attached is a pic of the bolts.
The bolt on the left in each set has been buffed/polished - actually came out pretty good. The bolt on the right is unpolished and is what I assume the polished ones will look like after a couple of washes if not plated.
Are these bolts coated with a material that requires any prep necessary other than cleaning/degreasing prior to plating with the Copy Chrome Plug n Plate kit? Thanks in advance for any advice. --Greg
