Hi, I am going to purchase a Copy Cad kit (1 gal) to plate various motorcycle parts, nuts bolts, brackets etc. My biggest part will be about 50 square inches on the external surface with an additional 50 square inches inside this hollow part. Since I do not need the inside plated, can the interior be masked in some way to remove it form the equation? Will the supplied power unit do this size piece effectively?
Copy Cad questions
You can use a lacquer to mask the inside.
Copy Cad requires 0.02 amps per square inch, so your 50 sq in part would require 1 amp to plate.--
