Re: plug and plate ??
Try about 3 mins per sq\".
plug and plate ??
The bolt was steel.
It is one of the many small parts from off of a motor cycle ,that I want to plate.
I now just have to figure out how long I
have to keep plate brushing any given area,to make the plating surface thick enough to be durable.I have several pieces of steel sheet metal that are 3\"x6\" in size.
That I want to plate, using the brush method.
The bolt head I have tried using the brush on method and dipping method.
Glen
What\'s the bolt made of? A unscientific check would be to leave the bolt outside for a few days to see if it rusts. If it does, it\'s not plated with Copy Chrome.
If you\'re just testing the kit - try it on a piece of copper or brass...where you\'ll be able to see the results more easily.
plug and plate ??
I sanded the paint off of a bolt head then polished it to a chrome like finnish.
I then used the copy chrome kit, as per the instructions. My quesions is, how do I know if it acualy plated it or not?.
It was so shinny and chrome like before I plated it.
Thanks for any advice!!
Glen HiggsTags: None
