Plating Capacity
  • Plating Capacity
    How many total square inches can be plated at .5/1000 with a 1 liter electroless nickel plating kit?
    From the EN Page:
    Our 1/2 Gallon kit (1 Liter) will plate approx. 150 sq. in. of surface area with a bright nickel @ 1 mil, or 600 sq. in. @ 0.25 mil.
      Plating Capacity
      How many ounces of distilled water are necessary in order to use the complete 1 liter kit at one time to plate 125 sqaure inches?
        What exactly is this part? To electroless nickel plate, you need to be able to immerse the entire part in the supplied tank...sounds like this might be a little big for a 1/2 Gallon Kit.
          Plating Capacity
          I want to plate 8 golf iron heads. Each being about 12-13 square inches.
          I would like to do them all at the same time.
            Well, the 1/2 Gallon kit comes with a tank that is 7" diam x 6" deep. I doubt you'll get all eight in there.
            If you send me an e-mail to [email protected], I'll send you the instruction booklet.
