I leave my acid copper and my flash copper anodes in because I plate with them about every day they set no longer than 3 days without use. how offen should I pull them and clean? Thanks Todd Breaden
copper anode maintiance??
Re: copper anode maintiance??
Tod
How?s it going let me start by saying that I would recommend that you pull them out at the end of the day when you are done and rinse them off . If you are not going to do this at least take them out and clean them before the next use. The reason for taking them out is longer life of the anode
and to keep solution from becoming contaminatedJim Eaton
i took mine out simply because i didnt plate on a daily basis, if you plate each day i would not remove them.
bill
